13 years agoLinux with MMU on DE2-115
Hi, Though the kernel version is still 2.6.30 and ether is limited up to 100Base-T, I uploaded a demonstration example for DE2-115. http://www.alterawiki.com/wiki/linux_with_mmu_on_veek/t...
13 years agoHi,
The data path of sound system is configured as follows, SYSTEM RAM <---> DMA <--> FIFO + I2S Interface (i2s_ctrl) <--> WM8731 so you need also the DMA driver. --- Quote Start --- Can you send me code for this driver? Or mabey driver is not needed, but only some configuration in linux files? --- Quote End --- And unfortunately, you need several new drivers for Linux sound system. Please refer the attached files. Kazu
