13 years agoLinux with MMU on DE2-115
Hi, Though the kernel version is still 2.6.30 and ether is limited up to 100Base-T, I uploaded a demonstration example for DE2-115. http://www.alterawiki.com/wiki/linux_with_mmu_on_veek/t...
13 years agoWell if the person responsible for the Altera wiki is the same one than for the forum, you may get an answer in 2-3 years :/
From your description it looks like they had a problem with the database and switched to a backup. The wiki is currently in an even more abandoned state than the forum, so I wouldn't consider it reliable right now. If you write articles there, you should at least keep some backups.
