21 years ago
linux_time_limited.sof
when i use Quartus II Programmer to download linux_time_limited.sof to the board ,there is info like that:
Info: SRAM Object File C:/altera/kits/nios2/examples/verilog/niosII_stratix_1s10/linux/linux_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x00A2
and i cannot flash it into the flash,how can i solve the problem!! thank you!
1 Reply
    As has been stated several times on this forum, you need to be using a licensed core in order to experiment with the flash. Don't question this fact, just accept it and move on :-)
    If your host system is a Linux PC, then you need to be using version 5.0 of both Quartus II and the Nios II stuff.
    Cheers,
    - slacker
