21 years agolinux_time_limited.sof
when i use Quartus II Programmer to download linux_time_limited.sof to the board ,there is info like that: Info: SRAM Object File C:/altera/kits/nios2/examples/verilog/niosII_stratix_1s10/linux...
21 years agoAs has been stated several times on this forum, you need to be using a licensed core in order to experiment with the flash. Don't question this fact, just accept it and move on :-)
If your host system is a Linux PC, then you need to be using version 5.0 of both Quartus II and the Nios II stuff. Cheers, - slacker
