15 years ago
Linux Kernel Compile Problem
Not sure if this is the correct location for this post but here goes anyway
I am building uClinux-dist from nios2-linux06212010
and using nios2-linux-gcc ver. 3.4.6
I am building the kernel up to the following point and then...
LD init/built-in.o
LD .tmp_vmlinux1
kernel/built-in.o(.init.text+0x54c): In function `sched_init_smp':
: undefined reference to `____ilog2_NaN'
: relocation truncated to fit: R_NIOS2_CALL26 ____ilog2_NaN
make[2]: *** [.tmp_vmlinux1] Error 1
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/home/nick/06212010-nios2-linux/nios2-linux/linux-2.6'
make: *** [linux] Error 1
Any help greatly appreciated!
Nick
    ok
    this version work better........
    use this tuttorial i will post
    good luck
    Franz Wagner
    OK, 1st problem....
    nick@nci3:~/20090929-nios2-linux/nios2-linux/uClinux-dist$ make vendor_hwselect SYSPTF=/home/nick/20090929-nios2-linux/SM3k_rev5.ptf ARCH=nios2
    make ARCH=nios2 -C vendors vendor_hwselect
    make[1]: Entering directory `/home/nick/20090929-nios2-linux/nios2-linux/uClinux-dist/vendors'
    make -C /home/nick/20090929-nios2-linux/nios2-linux/uClinux-dist/vendors///. dir_v=/home/nick/20090929-nios2-linux/nios2-linux/uClinux-dist/vendors///. -f /home/nick/20090929-nios2-linux/nios2-linux/uClinux-dist/vendors/vendors-common.mak vendor_hwselect
    make[2]: Entering directory `/home/nick/20090929-nios2-linux/nios2-linux/uClinux-dist/vendors'
    /home/nick/20090929-nios2-linux/nios2-linux/uClinux-dist/vendors/vendors-common.mak:9: *** target file `romfs.post' has both : and :: entries. Stop.
    make[2]: Leaving directory `/home/nick/20090929-nios2-linux/nios2-linux/uClinux-dist/vendors'
    make[1]: *** [vendor_hwselect] Error 2
    make[1]: Leaving directory `/home/nick/20090929-nios2-linux/nios2-linux/uClinux-dist/vendors'
    make: *** [vendor_hwselect] Error 2
    ok ......
    did you set the path ?
    PATH=$PATH:/opt/nios2/bin
    try make make menuconfig
    and make vendor......
    report
    Franz Wagner
