15 years agoLinux Kernel Compile Problem
Not sure if this is the correct location for this post but here goes anyway I am building uClinux-dist from nios2-linux06212010 and using nios2-linux-gcc ver. 3.4.6 I am building the ker...
15 years agook ......
did you set the path ? PATH=$PATH:/opt/nios2/bin try make make menuconfig and make vendor...... report Franz Wagner
