20 years agolinux 2.6.12 instability
hippo, I'm starting a new thread to keep track of this...
I think 2.6.12 looks better than .16 - it hasn't failed on me yet. the patches you gave me were a bit messy though, I think maybe some things were missing. I also get these warnings on every single file compiled: In file included from /share/nios2/tmp/linux-2.6.12/include/linux/sched.h:17, from /share/nios2/tmp/linux-2.6.12/include/linux/module.h:10, from /share/nios2/tmp/linux-2.6.12/init/version.c:10: /share/nios2/tmp/linux-2.6.12/include/linux/nodemask.h: In function `__first_unset_node': /share/nios2/tmp/linux-2.6.12/include/linux/nodemask.h:250: warning: passing arg 1 of `find_next_zero_bit' discards qualifiers from pointer target type Page allocation failures is one thing, but I'm more worried about the kernel hanging completely like .16 was doing. I also have a feeling it's the busybox version. I noticed that in 1.1.1, the file utilities were a bit messed up. For example, here is the output from a normal 'df -h': # busybox_old df -h Filesystem Size Used Available Use% Mounted on /dev/ram0 235.0k 14.0k 221.0k 6% /var /dev/ram1 235.0k 13.0k 222.0k 6% /tmp /dev/hda1 14.5M 12.3M 1.5M 89% /mnt/cf# Here is the output of 1.1.1 df -h: # df -h Filesystem Size Used Available Use% Mounted on /dev/ram0 235.0k 14.0k 221.0k 6% (null) /dev/ram1 235.0k 13.0k 222.0k 6% (null) /dev/hda1 14.5M 12.3M 1.5M 89% (null)# All the filesystem utilities, like mke2fs, du, e2fsck, are weird like this. I will keep playing around with 2.6.12 and see what happens.26 Replies
Just another tip,
I won't compile kernel in place, not in the source tree. I use "make .... O=~/board_1/kernel-branch " for each board and each version of kernel, the source tree must be clean first, with "make .... clean" and "make .... mrproper" . And each board can have a copy of rootfs of different apps setup. ~/board_1/rootfs I build kernel in the source tree for the buildroot guide, only because it would be easier for newbie. - Altera_Forum
That's a good patch system, I didn't know you had set it up that way - could I get the patch set for .14 and .16?
When I noticed the dd issue, I was using a Avalon system with pipelining enabled. When I addeda DMA component to the system, it locked everything up when I would try and access certain registers. It's definitely an Avalon bug, and I have my FAE looking into it. Anyway, I'm not using pipelining now, so I'm seeing if it makes a difference with this issue. - Altera_Forum
oh god, I would be in big trouble if I compiled directly in the tree! I have over 20 different configurations for my hardware, so it would be hell with 20 different copies of the source http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
I have a separate folder with a makefile that just handles all the cross-compiling stuff and pointing to the right source tree. http://via.dynalias.org/svn/uclinux/kernel...skeleton/trunk/ (http://via.dynalias.org/svn/uclinux/kernel_build/skeleton/trunk/) (just in case anyone is interested) - Altera_Forum
--- Quote Start --- originally posted by jdhar@Apr 13 2006, 02:03 PM oh god, i would be in big trouble if i compiled directly in the tree! i have over 20 different configurations for my hardware, so it would be hell with 20 different copies of the source http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gifi have a separate folder with a makefile that just handles all the cross-compiling stuff and pointing to the right source tree.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14315)
--- quote end ---
--- Quote End --- Ya, you knew it already. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
kernel logs (v0.2): http://via.dynalias.org/snapshots/linux-2.6.12-0.2.tar.bz2 (http://via.dynalias.org/snapshots/linux-2.6.12-0.2.tar.bz2)
------------------------------------------------------------------------ r908 | jdhar | 2006-04-13 01:37:07 -0400 (Thu, 13 Apr 2006) | 1 line v0.2 - moved over I2C Opencores and EPCS MTD Driver. zImage compressed image support also added ------------------------------------------------------------------------ r903 | jdhar | 2006-04-12 23:42:54 -0400 (Wed, 12 Apr 2006) | 1 line v0.1 - 2.6.12, minimally patched with MMC 0.1.4, open_eth, JTAG UART, CF. No MTD driver yet - Altera_Forum
--- Quote Start --- originally posted by jdhar@Apr 13 2006, 02:01 PM that's a good patch system, i didn't know you had set it up that way - could i get the patch set for .14 and .16?when i noticed the dd issue, i was using a avalon system with pipelining enabled. when i addeda dma component to the system, it locked everything up when i would try and access certain registers. it's definitely an avalon bug, and i have my fae looking into it. anyway, i'm not using pipelining now, so i'm seeing if it makes a difference with this issue.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14314)
--- quote end ---
--- Quote End --- You need to be very careful with DMA, the original 2.6.11 port of Microtronix did not handle DMA cache. And it is very important for PCI. Anyways, I fix them and my PCI is working well. Pipelineing is quite new. I had asked for it long ago. But it is still not usable for me up to now. Those patches are too big to post here. I have only 1MB quota here. Please give me an upload point to my private mail. I will prepare them when I have time.
The bug was weird actually..
if I had a simple system with just a DMA core tied to an SPI Device (I was trying to do DMA with my MMC core), and pipelining enabled, it would completely locku p the bus if I tried to even read an SPI Register without DMA enabled. I thought it was uClinux, so I used a simpel hello world in NIOS II IDE to read an SPI Register and it still locked up the system. I think they still have issues with pipelining, but only in more complex systems (I have 6 masters DMAing into DDR). No rush for those patches, I'll send an upload point. Thx. - Altera_Forum
--- quote end ---
--- Quote End --- patches for 2.6.12-2.6.16 uploaded. note the patches for the struct flip changed in serial/jtag uart rx in 2.6.16 .
--- Quote Start --- originally posted by hippo+apr 13 2006, 10:30 pm--><div class='quotetop'>quote (hippo @ apr 13 2006, 10:30 pm)</div>--- quote start ---
<!--quotebegin-jdhar@Apr 13 2006, 02:01 PM that's a good patch system, i didn't know you had set it up that way - could i get the patch set for .14 and .16?
--- quote end ---
--- Quote End --- patches for 2.6.12-2.6.16 uploaded. note the patches for the struct flip changed in serial/jtag uart rx in 2.6.16 . <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14338)</div> [/b] --- Quote End --- altpci patch posted, http://forum.niosforum.com/forum/index.php...ype=post&id=140 (http://forum.niosforum.com/forum/index.php?act=attach&type=post&id=140) but the patch work for 2.6.15 and 2.6.16 . it can not work in 2.6.11, the file arch/nios2nommu/mm/dma-noncoherent.c should be back ported from the one from arch/mips/mm . I don't have time to do it tonight. help yourself, please.
great work hippo ; i'm getting .14 in there now, and then i will try .16.
