20 years agolinux 2.6.12 instability
hippo, I'm starting a new thread to keep track of this... I think 2.6.12 looks better than .16 - it hasn't failed on me yet. the patches you gave me were a bit messy though, I think may...
20 years ago --- Quote Start --- originally posted by hippo+apr 13 2006, 10:30 pm--><div class='quotetop'>quote (hippo @ apr 13 2006, 10:30 pm)</div>
--- quote start ---
<!--quotebegin-jdhar@Apr 13 2006, 02:01 PM that's a good patch system, i didn't know you had set it up that way - could i get the patch set for .14 and .16?
when i noticed the dd issue, i was using a avalon system with pipelining enabled. when i addeda dma component to the system, it locked everything up when i would try and access certain registers. it's definitely an avalon bug, and i have my fae looking into it. anyway, i'm not using pipelining now, so i'm seeing if it makes a difference with this issue.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14314)
--- quote end ---
--- Quote End --- patches for 2.6.12-2.6.16 uploaded. note the patches for the struct flip changed in serial/jtag uart rx in 2.6.16 . <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14338)</div> [/b] --- Quote End --- altpci patch posted, http://forum.niosforum.com/forum/index.php...ype=post&id=140 (http://forum.niosforum.com/forum/index.php?act=attach&type=post&id=140) but the patch work for 2.6.15 and 2.6.16 . it can not work in 2.6.11, the file arch/nios2nommu/mm/dma-noncoherent.c should be back ported from the one from arch/mips/mm . I don't have time to do it tonight. help yourself, please.
