19 years agoKeyboard in nios ide
My keyboard stop to run after a few second and restart after a few second and restop ...
I can't use the IDE to edit my files the frequence is changing when I start The Debugger ... it comes quickly if I start and stop a few time the debugger ... I See that the Java takes 100% of the CPU time during this prolême if you have the same problem an you help me ? Thank's4 Replies
Well, i have seen cpu load peaks during debugging steps even with a 3.8GHz pc with realy enough memory.
So i can imagine higher peaks with a less equiped pc. Could you give a bit more information about the system you work with ? - Altera_Forum
a P4 3Giga 1 Giga of Ram
I can't run with this IDE like this I see that the JavaW Process take 100% of the ressource and don't let me type any char after a few second it becomes normaly but some second after it reappears. We have the same problem on each PC on whitch we have try it like dualcore or centrino Duo. Each time the javaw is request the size of the process becomes bigger and bigger and bigger. Thanks - Altera_Forum
Nios IDE is rathe slowly.( But is acceptable works on my Pentium M 1,5Ghz).
Try to use Codelab Debug for NiosII. - Altera_Forum
this don't help me.
I must use The Nios IDE but it's unusable. When I launch The IDE and I write some charactere. If I stop a few second I must wait 10 Seconds to see the cursor in a normal State. and it's only in the IDE of the Nios I don't think it's in Eclypse cause I use Delphi 2006 who use too Eclipse.
