19 years agoKeyboard in nios ide
My keyboard stop to run after a few second and restart after a few second and restop ... I can't use the IDE to edit my files the frequence is changing when I start The Debugger ... it come...
19 years agoWell, i have seen cpu load peaks during debugging steps even with a 3.8GHz pc with realy enough memory.
So i can imagine higher peaks with a less equiped pc. Could you give a bit more information about the system you work with ?
