21 years agoKernell would not build
The kernell would not build.
Microtronix Linux Extensions
Version 1.3, Built December 30th, 2004
make: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'
no emulation specific options.
Using /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x as source for kernel
CHK include/linux/version.h
CHK include/nios2_system.h
HOSTCC scripts/basic/fixdep
scripts/basic/.fixdep.d: done.
HOSTCC scripts/basic/split-include
scripts/basic/.split-include.d: done.
HOSTCC scripts/basic/docproc
scripts/basic/.docproc.d: done.
HOSTCC scripts/mod/mk_elfconfig
scripts/mod/.mk_elfconfig.d: done.
MKELF scripts/mod/elfconfig.h
HOSTCC scripts/mod/file2alias.o
scripts/mod/.file2alias.o.d: done.
HOSTCC scripts/mod/modpost.o
scripts/mod/.modpost.o.d: done.
HOSTCC scripts/mod/sumversion.o
scripts/mod/.sumversion.o.d: done.
HOSTLD scripts/mod/modpost
HOSTCC scripts/kallsyms
scripts/.kallsyms.d: done.
make: `arch/nios2nommu/kernel/asm-offsets.s' is up to date.
CHK include/asm-nios2nommu/asm-offsets.h
CHK include/linux/compile.h
HOSTCC usr/gen_init_cpio
usr/.gen_init_cpio.d: done.
CPIO usr/initramfs_data.cpio
GZIP usr/initramfs_data.cpio.gz
AS usr/initramfs_data.o
usr/.initramfs_data.o.d: done.
LD usr/built-in.o
CC drivers/char/spi.o
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:34: error: parse error before '*' token
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:34: warning: type defaults to `int' in declaration of `spi_ptr'
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:34: warning: initialization makes pointer from integer without a cast
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:34: warning: data definition has no type or storage class
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `SPI_Recv_Byte':
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:49: error: request for member `np_spistatus' in something not a structure or union
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:49: error: `np_spistatus_rrdy_mask' undeclared (first use in this function)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:49: error: (Each undeclared identifier is reported only once
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:49: error: for each function it appears in.)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:50: error: request for member `np_spirxdata' in something not a structure or union
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `SPI_Send_Byte':
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:62: error: request for member `np_spistatus' in something not a structure or union
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:62: error: `np_spistatus_trdy_mask' undeclared (first use in this function)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:63: error: request for member `np_spitxdata' in something not a structure or union
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `spi_write':
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:102: error: request for member `np_spistatus' in something not a structure or union
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `spi_read':
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:154: error: request for member `np_spistatus' in something not a structure or union
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `spi_lseek':
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:221: error: request for member `np_spislaveselect' in something not a structure or union
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `register_NIOS_SPI':
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:272: warning: `check_region' is deprecated (declared at /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/include/linux/ioport.h:121)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:272: error: `np_spi' undeclared (first use in this function)
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c: In function `unregister_NIOS_SPI':
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/char/spi.c:288: error: `np_spi' undeclared (first use in this function)
make: *** Error 1
make: *** Error 2
make: *** Error 2
make: *** Error 2
make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x' If i disable the SPI in the kernell configurator the kernell will build without error's Can someone help ?5 Replies
nobody used SPI???? tell me if you are using it! and it working
I had the same problem and IMO the SPI component generator has a bug. IIRC I corrected it and was able to compile the kernel after that. If there is no official fix for this I can post it if you want.
Marc - Altera_Forum
Yes please that would be nice !
Did the SPI bus work? Do you have got a any example application? I appriciate it, if you want post it. Tnx now can i graduate at time i hope. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif - Altera_Forum
I don't remember exactly what I did. I think the include file was missing some parts and the perl generator was bugged. I don't know how to add files to a post so I will just paste the code:
With this I just compiled the kernel and started uclinux but I haven't used it yet. I am supposed to play with this next week. So if you manage to make it work I would be interested to know ;-) Also if there is an official fix I'm interested too. Marc File: altera\kits\nios2\bin\eclipse\plugins\com.microtronix.nios2linux.kernel_0.1.5\linux-2.6.x\include\asm-nios2nommu\spi.h
File: altera\kits\nios2\bin\eclipse\plugins\com.microtronix.nios2linux.kernel_0.1.5\linux-2.6.x\arch\nios2nommu\scripts\nios2_system.h\altera_avalon_spi.pm#ifndef _ASM_SPI_H_# define _ASM_SPI_H_ 1 /*-------------------------------------------------------------------- * * include/asm-nios2nommu/spi.h * * Derived from various works, Alpha, ix86, M68K, Sparc, ...et al * * Copyright (C) 2004 Microtronix Datacom Ltd * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * * Jan/20/2004 dgt NiosII * ---------------------------------------------------------------------*/ # include <asm/nios.h> int register_NIOS_SPI( void ); void unregister_NIOS_SPI( void ); # if defined(MODULE) void cleanup_module( void ); int init_module( void );# endif # if defined(__KERNEL__) int spi_reset ( void );# endif # define clockCS 0x01# define temperatureCS 0x02 # define clock_read_base 0x00# define clock_write_base 0x80# define clock_read_control 0x0F# define clock_read_trickle 0x11 # define clock_read_sec 0x00# define clock_read_min 0x01# define clock_read_hour 0x02# define clock_read_day 0x03# define clock_read_date 0x04# define clock_read_month 0x05# define clock_read_year 0x06 # define clock_write_control 0x8F# define clock_write_trickle 0x91# define clock_write_sec 0x80# define clock_write_min 0x81# define clock_write_hour 0x82# define clock_write_day 0x83# define clock_write_date 0x84# define clock_write_month 0x85# define clock_write_year 0x86 # define clock_write_ram_start 0xA0# define clock_write_ram_end 0x100# define clock_read_ram_start 0x20# define clock_read_ram_end 0x80 # define clock_sec_def 0x11# define clock_min_def 0x59# define clock_hour_def 0x71# define clock_day_def 0x00# define clock_date_def 0x20# define clock_month_def 0x12# define clock_year_def 0x34 # define temp_read_base 0x00# define temp_write_base 0x80# define temp_read_control 0x00# define temp_write_control 0x80# define temp_read_msb 0x02# define temp_read_lsb 0x01 # define MAX_TEMP_VAR 10 // SPI Registers typedef volatile struct { int np_spirxdata; // Read-only, 1-16 bit int np_spitxdata; // Write-only, same width as rxdata int np_spistatus; // Read-only, 9-bit int np_spicontrol; // Read/Write, 9-bit int np_spireserved; // reserved int np_spislaveselect; // Read/Write, 1-16 bit, master only int np_spiendofpacket; // Read/write, same width as txdata, rxdata. } np_spi; // SPI Status Register Bits enum { np_spistatus_eop_bit = 9, np_spistatus_e_bit = 8, np_spistatus_rrdy_bit = 7, np_spistatus_trdy_bit = 6, np_spistatus_tmt_bit = 5, np_spistatus_toe_bit = 4, np_spistatus_roe_bit = 3, np_spistatus_eop_mask = (1 << 9), np_spistatus_e_mask = (1 << 8), np_spistatus_rrdy_mask = (1 << 7), np_spistatus_trdy_mask = (1 << 6), np_spistatus_tmt_mask = (1 << 5), np_spistatus_toe_mask = (1 << 4), np_spistatus_roe_mask = (1 << 3), }; // SPI Control Register Bits enum { np_spicontrol_sso_bit = 10, np_spicontrol_ieop_bit = 9, np_spicontrol_ie_bit = 8, np_spicontrol_irrdy_bit = 7, np_spicontrol_itrdy_bit = 6, np_spicontrol_itoe_bit = 4, np_spicontrol_iroe_bit = 3, np_spicontrol_sso_mask = (1 << 10), np_spicontrol_ieop_mask = (1 << 9), np_spicontrol_ie_mask = (1 << 8), np_spicontrol_irrdy_mask = (1 << 7), np_spicontrol_itrdy_mask = (1 << 6), np_spicontrol_itoe_mask = (1 << 4), np_spicontrol_iroe_mask = (1 << 3), }; // SPI Routines. int nr_spi_rxchar(np_spi *spiBase); int nr_spi_txchar(int i, np_spi *spiBase); # endif /*_ASM_SPI_H_*/package altera_avalon_spi; # This module renames the first altera_avalon_spi peripheral to spi require PTF::SystemPTF; require PTF::SystemPTF::Module; use strict; sub run { my ($system, @spi_names) = @_; my %module_map = ( "spi" => undef, ); my @module_map_order = ("spi"); foreach my $module_name (@module_map_order) { my $module = $system->getModule ($module_name); # determine availability of each module_name if ($module) { my $class_name = $module->getClass (); if ($class_name ne 'altera_avalon_spi') { print "#error The module name $module_name is of class $class_name.\n"; print "#error This will break the kernel.\n"; print "#error Please rename the module to something else in SOPC Builder.\n\n"; } else { print "/* No translation for $module_name necessary */\n\n"; } } else { # if module name is available, take first uart and translate while (scalar (@spi_names) > 0) { my $spi_name = shift (@spi_names); if (!exists $module_map{$spi_name}) { my $module = $system->getModule ($spi_name); my $result; print "/* Redefining $spi_name -> $module_name */\n"; # start outputing necessary strings print "#undef na_" . $spi_name . "\n"; print "#undef na_" . $spi_name . "_irq\n"; print "\n"; # base address information $result = $module->getBaseAddress (); printf ("#define na_%-50s %#010x\n", ($module_name, hex ($result) | 0x80000000)); # irq information $result = $module->getIRQ (); printf ("#define na_%-30s %30s\n", ($module_name . "_irq", $result)); print "\n"; last; } } } } } 1; - Altera_Forum
The kernell is build witout error's
I will upload it tommorow to my board. And see if it working, but i have no appication to test it. I have not find any fix for it, maybe someone from Microtronix know it? Maybe 2 SPI interface will also work ?
