21 years ago
Kernel continuously rebooting
I am running linux 2.6 on a Altera Cyclone II Nios II dev board. I have created a system, kernal and file system. Every thing compiled, no problems but the kernel keep on rebooting after ---
Linux version 2.6.11-uc0 (Administrator@xaibear) (gcc version 3.4.1 (Altera Nios
II 5.0 b73))# 3 Tue Aug 23 11:45:05 SAST 2005
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 007F0000
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 256 (order: 8, 4096 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory available: 30592k/32768k RAM, 0k/0k ROM (1499k kernel code, 309k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
NIOS serial driver version 0.0
ttyS0 (irq = 4) is a builtin NIOS UART
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x821208d0 (irq = 1) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
smc_probe: 85000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x82110300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:
ed:00:00:00
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=8
Altera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 4 MTD partitions on "Altera NDK flash (AMD)":
0x00200000-0x00800000 : "romfs/jffs2"
0x00000000-0x00200000 : "loader/kernel"
0x00800000-0x00c00000 : "User configuration"
0x00c00000-0x01000000 : "safe configuration"
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
NET: Registered protocol family 17
At this point it keeps rebooting
What is the problem and what should actually happen next???
Thank for your help
    Hi all
    I read all the other topics and threads, followed the guides. The exception address is in ddr sdram. I have tried negating the compact flash and the lan91c111 individually and all together. Nothing works.
    I'd appretiate any help?
    Hey Rual,
    I've been encountering the same issue as yourself, and I posted it in an earlier thread, as a continuation to an earlier problem. I suppose it would've made more sense to start a new one up. I'll repost here, where it belongs. The only difference between you and I is that I'm using the Altera Stratix II DSP board, which there isn't a supplied Microtronix uClinux example for. Therefore, I have to generate the romfs from command line instead of using the developer, a known issue.
    repost
    I&#39;m still getting a continual reboot. It doesn&#39;t seem to matter if I use <base addy of flash> as from my core design or from the flash programmer for the command line genromfs execute. And yes, I clear flash before trying one or the other to ensure it&#39;s not a previous burn. However, one run went farther than any other and reported an error near the beginning and at the end that perhaps someone else is familiar with. Here&#39;s my boot sequence.
    uClinux/Nios II
    setup_arch: No persistant network settings signature at 00FF0000
    Built 1 zonelists
    PID hash table entries: 128 (order: 7, 2048 bytes)
    Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
    Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Memory available: 14472k/16384k RAM, 0k/0k ROM (1422k kernel code, 296k data)
    ttyJ0 at MMIO 0x82120940 (irq = 1) is a jtag_uart
    smc_probe: 50000 Khz Nios
    microtronix[mtd]: RAM probe address=0x200000 size=0x0
    Creating 1 MTD partitions on "RAM":
    0x00000000-0x00000000 : "ROMfs"
    mtd: partition "ROMfs" is out of reach -- disabled
    microtronix[mtd]: set ROMfs to be root filesystem
    TCP established hash table entries: 1024 (order: 1, 8192 bytes)
    TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
    TCP: Hash tables configured (established 1024 bind 1024)
    Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)
    Keplin,
    I&#39;m not sure your problems are the same. Looks like your problem lies with the file system you are creating.
    The size is 0, and its address conficts with you flash ROMfs
    Doug
    Wait a minute, so the Kernel still thinks my romfs is located in 0x200000 on flash? I generated the filesystem under the command line and placed it at location 0x500000 instead. This is due to the fact that the DSP board has a different config and addresses factory at 0x200000, with that declared in the PTF. Could the Kernel be looking in the PTF and seeing that there&#39;s a config already located at 0x200000, therefore thinking there&#39;s a size of 0x0 (being 0x200000 to 0x200000)?
    How do I then point the Kernel to the right location to find the filesystem?
    Thanks for any help,
    Matt
    Matt,
    Update your altera.c file located in:
    /***/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/mtd/maps/altera.c
    Should probably copy it first to something like altera.c.orig (keep the original). Then update altera.c with what you want.
    Doug
    Keplin & Matt
    Thanks for your help
    I found some inconsistencies in the size of the flash allocated by uClinux for my system. I also found that the address lines for the flash chip has an offset in SOPC builder. The SOPC builder component&#39;s address[0] should be assigned to D15.A1, address[1] to A0 ......
    My system is now running OK
    Thanks again http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
