20 years ago
Kernel configuration
Hi ,
I am using NIOS IDE 5.0 and uClinux1.4 plugin.
After I create a new Kernel project by selecting "File-New-Project...-Linux Kernel Project" , then I right-click on it to configure but don't see any items named "Configure Kernel" in the context menu as "Linux Quick Start Guide.pdf" shows.
Did I miss something ?
One strange thing is that after I create a FileSystem Project , then I see the item of "Configure Kernel" in the context menu but it is DISABLED !!!!
What is the problem of mine ?
Thanks in advance,
Quan
    hi
    I thing the problem is that u have to be in navigator view within Eclipse http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
    I hope these is the problem
    good luck http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
    --- Quote Start ---
    originally posted by quan1328@Apr 21 2006, 08:51 AM
    hi ,
    i am using nios ide 5.0 and uclinux1.4 plugin.
    after i create a new kernel project by selecting "file-new-project...-linux kernel project" , then i right-click on it to configure but don&#39;t see any items named "configure kernel" in the context menu as "linux quick start guide.pdf" shows.
    did i miss something ?
    one strange thing is that after i create a filesystem project , then i see the item of "configure kernel" in the context menu but it is disabled !!!!
    what is the problem of mine ?
    thanks in advance,
    quan
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14542)
    --- quote end ---
    --- Quote End ---
    You can also run the kernel configurator by double-clicking the configure.bat file.
    Hi geisler , sdhnain
    I got and corrected it as you suggested , everything is fine now.
    Quan
