19 years ago
kbhit() in C
I searching for an implementation of kbhit() from <conio.h> in C. I want to use this function for the Terminal in the eclipse IDE.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif Thx a lot for your help
    I&#39;m not sure if i understand you correctly but take a look at the "Board Diagnostics"-Template in Nios II IDE. There is a function called getchar() used for this.
    Hi cece,
    Thx for your answere. But getchart don&#39;t solve my problem, because its a blocking function. This means, if no key is pressed, the function getchar blocks until a key is pressed. With kbhit it is possible just to test, if an key was pressed(without blocking).
    -> with the help of <termios.h> it should be possible to programm a kbhit function, but the functions :
    - tcgetatt
    - tcsetattr
    from termios.h doesnt&#39;t work ??? Any other solutions are welcome
    Here the code :
    int getch()
    static int ch = -1, fd = 0;
    struct termios neu, alt;
    fd = fileno(stdin);
    tcgetattr(fd, &alt);
    neu = alt;
    neu.c_lflag &= ~(ICANON|ECHO);
    tcsetattr(fd, TCSANOW, &neu);
    ch = getchar();
    tcsetattr(fd, TCSANOW, &alt);
    return ch;
    int kbhit(void)
    struct termios term, oterm;
    int fd = 0;
    int c = 0;
    tcgetattr(fd, &oterm);
    memcpy(&term, &oterm, sizeof(term));
