19 years agokbhit() in C
Hi, I searching for an implementation of kbhit() from <conio.h> in C. I want to use this function for the Terminal in the eclipse IDE. http://forum.niosforum.com/work2/style_emoticons/<...
19 years agoI'm not sure if i understand you correctly but take a look at the "Board Diagnostics"-Template in Nios II IDE. There is a function called getchar() used for this.
