21 years agoJTAG uart usage
Hi
Maby i'ts stupid quastion, but anyway i ask. Is it possible to use Jtag uart in NIos2 system like terminal for exchage commands. For example i write in C++ code some - printf("hello world"); and that "hello word" shown on my PC in some window If yes, give me,please the link with documentation or just tell me how to do it. tnx.3 Replies
you can use the jtag to communicate with the integrated terminal in
the debugger, but not with user programs (no description, how to access the jtag device from user pc programs) under your debugger NIOS II harwareconfiguration->Tab "Target Connection" you can set NiosII Terminal communication device to your jtag_uart. in your system library properties you can set stdout,stderr,stdin to your jtag_uart, then you can use normal printf("hello world"). otherwise FILE* jtfp; ... jtfp = fopen ("/dev/jtag_uart","rw"); if(jtfp) { fprintf(jtfp,"JTAG UART OPEN FOR DEBUG\n"); } - Altera_Forum
The JTAG UART handling program on the host is nios2-terminal. This is what is used by the IDE to communicate with the target.
You can use this from the SDK shell (or from any other shell which has the path set up correctly). It has quite extensive help text available using `nios2-terminal --help` if you're not happy with the standard options. - Altera_Forum
Is there a way to access the JTAG UART directly from a windows app. perhaps by redirecting the IO from nios2-terminal?
The xxxBlaster cables use either the parallel port or USB, but getting at the uart at this low level is probably not the way to go. thanks
