21 years agoJTAG uart usage
Hi Maby i'ts stupid quastion, but anyway i ask. Is it possible to use Jtag uart in NIos2 system like terminal for exchage commands. For example i write in C++ code some - printf...
21 years agoyou can use the jtag to communicate with the integrated terminal in
the debugger, but not with user programs (no description, how to access the jtag device from user pc programs) under your debugger NIOS II harwareconfiguration->Tab "Target Connection" you can set NiosII Terminal communication device to your jtag_uart. in your system library properties you can set stdout,stderr,stdin to your jtag_uart, then you can use normal printf("hello world"). otherwise FILE* jtfp; ... jtfp = fopen ("/dev/jtag_uart","rw"); if(jtfp) { fprintf(jtfp,"JTAG UART OPEN FOR DEBUG\n"); }
