himanshuvaria's avatar
himanshuvaria
2 years ago
Is it possible to run NIOSV through SDRAM ?
I am developing a project where NIOS II needs to replaced with NIOSV processor. When my design was having NIOS II as CPU, I was running the software code through External SDRAM on the Cyclone IV E Kit(EP4CE40F23C8). It's working fine with NIOS II. Able to run the software program.
Now, when I replaced the NIOS II processor with the NIOSV processor, I am not getting the expected results. I am trying to print a Simple "Hello World" code through the NIOSV processor with the same configuration of design. Almost all BSP settings are same for NIOSV processor as of the NIOS II. Still not getting the results.
When running the NIOSV from On-Chip-Ram, everything works as expected, but when I try to run the NIOSV through external SDRAM, the code does not gets executed as expected.
I want to inquire that if we can run the NIOSV processor through external SDRAM or not ?
Please note that I am not talking here about booting the NIOSV. I am simply running the software image through RiscFree IDE software on the external SDRAM of the board.
Himanshu
  • monkstein88's avatar
    monkstein88
    Hi @Vincent_F ,
    I think I have a solution for you if you are still experiencing the problem. Just DM me or write here - I'll share a link if needed.
