Is HW breakpoint required for SW breakpoint ?
Thanks for your efforts!
The design is well established for many years (and works flawlessly), I am new to this codebase and trying to step through to learn the code and logic. I could do printf(), but that's not good enough, I need to step through and have a look at registers, etc.
The design compiles and loads to the HW. Everything works fine.
I am trying to add breakpoint to step through the Application code and am not able to. Upon further investigation, I found the details as shared above, and will try to regenerate bsp(keeping the sof file constant), and if that doesn't work, will regenerate HW sof files with HW breakpoint and traces added, to see if that works.
I will update here with the results, and if I am able to make it break.
The details already shared are probably most I can share.
Thanks again!
