15 years ago
IORD IOWR macros vs. memory access to peripherals
What is the point of the IORD and IOWR macros? I can access my custom Avalon peripherals using them, but it seems like I can't access them like the following:
volatile alt_u32 *DEV_PTR = DEV_0_BASE;
alt_u32 data_in = 0;
data_in = DEV_PTR[0];
However, I CAN access the Altera CFI flash memory peripheral using the simple memory access method shown above and read my flash! I do not understand the distinctions. I do understand that the macros avoid the cache.
Thanks!
    Yes, but I'm sure the waitrequest of the peripheral it is always low.
    The only particuliarity of the slave peripheral is the latency: in the read process the data is registered. There is same problem if the read latency is different to 0 ?
    If you have a waitrequest signal, I don't think that the read latency parameter is used by the switch fabric anyway.
    If the waitrequest signal is low there is really no reason why the CPU should freeze. Are you sure that the address that you use in the IORD macro is actually the right one?
    Are the CPU data master and your custom component on the same clock domain? If not, could you check if the clock for your component's slave interface is actually running?
    Is your design properly constrained and does it meet all timing requirements?
    hey guys im new to sopc,nios design..
    my intention is to instantiate nios2 n sram .do read write operations via c program.
    i configured FPGA with nios2 processor and SRAM from university programm(DE1 BOARD,CYCLONE). IF WE HAVE MACROS TO ACCESS MEMORY THEN what about the pins of sram. how do i write into those pins in C language. we suppose to write in memory mapped memory adresses of pins assigned by SOPC . but it wont giv address map for those controll pins of sram. it only states initial address of sram.
    pls help..
    this is instantiated VHDL code.
    component rams is
    port (
    -- 1) global signals:
    signal clk_0 : IN STD_LOGIC;
    signal reset_n : IN STD_LOGIC;
    -- the_income
    signal in_port_to_the_income : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
    -- the_outgo
    signal out_port_from_the_outgo : OUT STD_LOGIC_VECTOR (7 DOWNTO 0);
    -- the_sram_0
    signal SRAM_ADDR_from_the_sram_0 : OUT STD_LOGIC_VECTOR (17 DOWNTO 0);
    signal SRAM_CE_N_from_the_sram_0 : OUT STD_LOGIC;
    signal SRAM_DQ_to_and_from_the_sram_0 : INOUT STD_LOGIC_VECTOR (15 DOWNTO 0);
    signal SRAM_LB_N_from_the_sram_0 : OUT STD_LOGIC;
    signal SRAM_OE_N_from_the_sram_0 : OUT STD_LOGIC;
    signal SRAM_UB_N_from_the_sram_0 : OUT STD_LOGIC;
    signal SRAM_WE_N_from_the_sram_0 : OUT STD_LOGIC
    end component rams;
    it gives mem mapped adress of income n outgo(these r pio_0 n pio_1).
    but not for other signals out there.
    You don't directly control the pins from the software. Just access the memory from your code through pointers and/or the IOWR/RD macros and the hardware will control the sram pins accordingly.
