16 years agoIORD IOWR macros vs. memory access to peripherals
What is the point of the IORD and IOWR macros? I can access my custom Avalon peripherals using them, but it seems like I can't access them like the following: volatile alt_u32 *DEV_PTR = DEV_...
15 years agohey guys im new to sopc,nios design..
my intention is to instantiate nios2 n sram .do read write operations via c program. i configured FPGA with nios2 processor and SRAM from university programm(DE1 BOARD,CYCLONE). IF WE HAVE MACROS TO ACCESS MEMORY THEN what about the pins of sram. how do i write into those pins in C language. we suppose to write in memory mapped memory adresses of pins assigned by SOPC . but it wont giv address map for those controll pins of sram. it only states initial address of sram. pls help.. this is instantiated VHDL code. component rams is port ( -- 1) global signals: signal clk_0 : IN STD_LOGIC; signal reset_n : IN STD_LOGIC; -- the_income signal in_port_to_the_income : IN STD_LOGIC_VECTOR (7 DOWNTO 0); -- the_outgo signal out_port_from_the_outgo : OUT STD_LOGIC_VECTOR (7 DOWNTO 0); -- the_sram_0 signal SRAM_ADDR_from_the_sram_0 : OUT STD_LOGIC_VECTOR (17 DOWNTO 0); signal SRAM_CE_N_from_the_sram_0 : OUT STD_LOGIC; signal SRAM_DQ_to_and_from_the_sram_0 : INOUT STD_LOGIC_VECTOR (15 DOWNTO 0); signal SRAM_LB_N_from_the_sram_0 : OUT STD_LOGIC; signal SRAM_OE_N_from_the_sram_0 : OUT STD_LOGIC; signal SRAM_UB_N_from_the_sram_0 : OUT STD_LOGIC; signal SRAM_WE_N_from_the_sram_0 : OUT STD_LOGIC ); end component rams; it gives mem mapped adress of income n outgo(these r pio_0 n pio_1). but not for other signals out there.
