12 years ago
IORD and IOWR issues
Hello there,
I am struggling to understand a simple write and read with the nios processor.
With qsys, I have setup a simple testcase where a nios (e) with no cache and a PIO are connected. PIO is connected to the external LEDs.
With the DE0NAN0 board, I can easily see the LEDs to change to what value I have put on the eclipse program.
e.g IOWR(PIO_BASE,0,0xA);
Then, I manually changed the qsys generated pio.led such that
data_out <= {writedata[5:0],1'b1};
instead of
the original data_out <= writedata[5:0];
and ensured that the qsys does not generate the nios and pio again during the compilation.
Afterwards, with eclipse program, I do a
printf("%X ",IORD(PIO_BASE,0));
I was expecting that "10101" in binary from a IOWR of 0xA.
However, it reads "0xA".
Can anyone please shed some light what I am doing wrong here ?
    If data_out has the original 6bit data width, you should write
    data_out <= {writedata[4:0],1'b1};
    otherwise I think the compiler discards the added bit.
    Nice catch. however it was just a typo I made when writing that post
    the original version from qsys was
    data_out <= writedata[6:0];
    --- Quote Start ---
    --- Quote End ---
    Make sure Nios doesn't perform a cache access instead of the actual IORD access.
    Flush the cache between the two instructions or force IORD to be uncached by setting address bit 31.
    I have
    - verified the logic on the technology map
    - set address bit 31 as you recommended
    - on system.h, NIOS2_DCACHE_SIZE and NIOS2_ICACHE_SIZE = 0
    still I dont have the expected "10101" in binary from a IOWR of 0xA.
    HW: data_out <= {writedata[5:0],1'b1};
    Observed behaviour on both the LEDs and with IORD suggest that the implementation is
    Do you have any other idea how to debug that ?
    I would recommend you then to verify if the correct .sof file is being uploaded.
