20 years agoIntroduction to SOPC builder
I am a complete noob http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif to nios and quartus and SOPC too. I need to use them as a part of project. I would be grateful if you could direct me to any helpful stuff which starts right from scratch. I rally have no idea. I have tried the altera web site but it doesnot offer a good help..(may be i overlooked something). So please take pain to help me out of this trouble.
Thnx in advance.http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Santosh3 Replies
This is the result of running a generator on a custom nios module built using SOPC Builder on NIOS2
Running Generator Program for cpu eperl: SOPC_KIT_NIOS2 environment variable not set Error: Generator program for module 'cpu' did NOT run successfully. generator cmd was '/tools/altera/quartus5/linux/perl561/bin/perl -I/tools/altera/quartus5/sopc_builder/bin -I/tools/altera/quartus5/sopc_builder/bin/europa -I/tools/altera/quartus5/sopc_builder/bin/perl_lib -I/local/linux/lib/perl5/5.6.1/i686-linux -I/local/linux/lib/perl5/5.6.1 -I/local/linux/lib/perl5/site_perl/5.6.1/i686-linux -I/local/linux/lib/perl5/site_perl/5.6.1 -I/local/linux/lib/perl5/site_perl -I. -I/tools/altera/kits/nios2/components/altera_nios2 -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s10_es -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_2s60_es -I/tools/altera/kits/nios2/components/altera_nios_custom_instr_endian_converter -I/tools/altera/kits/nios2/components/amd_avalon_am29lv128m_flash -I/tools/altera/kits/nios2/components/altera_nios_dev_kit_stratix_edition_sram -I/tools/altera/kits/nios2/components/amd_avalon_am29lv065d_flash -I/tools/altera/quartus5/sopc_builder/components/altera_sopc_builder -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s40 -I/tools/altera/kits/nios2/components/altera_nios2 -I/tools/altera/kits/nios2/components/altera_nios_dev_board_cyclone_2c35 -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_clock_adapter -I/tools/altera/kits/nios2/components/altera_avalon_spi -I/tools/altera/kits/nios2/components/altera_avalon_cfi_flash -I/tools/altera/kits/nios2/components/altera_avalon_dma -I/tools/altera/kits/nios2/components/altera_avalon_mailbox -I/tools/altera/quartus5/sopc_builder/components/altera_ahb_avalon_bridge -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_avalon_ahb_bridge -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_tri_state_bridge -I/tools/altera/kits/nios2/components/altera_nios_eval_board_cyclone_1c12 -I/tools/altera/kits/nios2/components/altera_avalon_lan91c111 -I/tools/altera/kits/nios2/components/altera_avalon_lcd_16207 -I/tools/altera/kits/nios2/components/altera_nios_dev_kit_stratix_edition_sram2 -I/tools/altera/kits/nios2/components/altera_avalon_cf -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_burst_adapter -I/tools/altera/kits/nios2/components/altera_nios_multiply -I/tools/altera/kits/nios2/components/altera_nios_dev_board_cyclone_1c20 -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_user_defined_interface -I/tools/altera/kits/nios2/components/altera_avalon_cy7c1380_ssram -I/tools/altera/kits/nios2/components/altera_plugs_library -I/tools/altera/kits/nios2/components/altera_avalon_cs8900 -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s10 -I/tools/altera/kits/nios2/components/altera_avalon_jtag_uart -I/tools/altera/kits/nios2/components/altera_avalon_asmi -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_onchip_memory -I/tools/altera/kits/nios2/components/altera_avalon_onchip_memory2 -I/tools/altera/kits/nios2/components/altera_avalon_timer -I/tools/altera/kits/nios2/components/altera_avalon_new_sdram_controller -I/tools/altera/kits/nios2/components/altera_nios_custom_instr_bitswap -I/tools/altera/kits/nios2/components/altera_avalon_epcs_flash_controller -I/tools/altera/kits/nios2/components/altera_avalon_performance_counter -I/tools/altera/kits/nios2/components/altera_avalon_sysid -I/tools/altera/kits/nios2/components/altera_avalon_mutex -I/tools/altera/kits/nios2/components/altera_avalon_uart -I/tools/altera/kits/nios2/components/altera_nios_custom_instruction -I/tools/altera/kits/nios2/components/altera_user_board_setup -I/tools/altera/kits/nios2/components/altera_avalon_pio /tools/altera/kits/nios2/components/altera_nios2/cpu_core_select.pl --system_name=first_nios2_system --target_module_name=cpu --system_directory=/export/home/santosh/BTP/nios_learn --sopc_directory=/tools/altera/quartus5/sopc_builder --sopc_lib_path=/export/home/santosh/BTP/nios_learn+/tools/altera/kits/nios2/components+/tools/altera/kits/megacore+/tools/altera/quartus5+/tools/altera/quartus5/sopc_builder/components --generate=1 --verbose=0 --software_only=0 --module_lib_dir=/tools/altera/kits/nios2/components/altera_nios2 --sopc_quartus_dir=/tools/altera/quartus5 --projectname=nios_learn.quartus ' Error in processing. System NOT successfully generated. Can anyone help to understand what this means I as stated b4 am a noob to this nios. So details will be greatly appreciated Thanx in advance Santosh - Altera_Forum
Here's the source of the error you're seeing:
How did you get to this point? SOPC_KIT_NIOS2 should be added to your environment when installing Nios II. Providing more details of what you've done, to get here, as well as what versions of Quartus II and Nios II you are using would certainly help us to help you. Cheers, - slackereperl: SOPC_KIT_NIOS2 environment variable not set - Altera_Forum
thanx a lot slacker, the post helped me identify source of the problem. i set the path as you suggested. now its working and generating the .bdf file.
Santosh
