20 years agoIntroduction to SOPC builder
I am a complete noob http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif to nios and quartus and SOPC too. I need to use them as a part of project. I would be grateful if you could...
20 years agoThis is the result of running a generator on a custom nios module built using SOPC Builder on NIOS2
Running Generator Program for cpu eperl: SOPC_KIT_NIOS2 environment variable not set Error: Generator program for module 'cpu' did NOT run successfully. generator cmd was '/tools/altera/quartus5/linux/perl561/bin/perl -I/tools/altera/quartus5/sopc_builder/bin -I/tools/altera/quartus5/sopc_builder/bin/europa -I/tools/altera/quartus5/sopc_builder/bin/perl_lib -I/local/linux/lib/perl5/5.6.1/i686-linux -I/local/linux/lib/perl5/5.6.1 -I/local/linux/lib/perl5/site_perl/5.6.1/i686-linux -I/local/linux/lib/perl5/site_perl/5.6.1 -I/local/linux/lib/perl5/site_perl -I. -I/tools/altera/kits/nios2/components/altera_nios2 -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s10_es -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_2s60_es -I/tools/altera/kits/nios2/components/altera_nios_custom_instr_endian_converter -I/tools/altera/kits/nios2/components/amd_avalon_am29lv128m_flash -I/tools/altera/kits/nios2/components/altera_nios_dev_kit_stratix_edition_sram -I/tools/altera/kits/nios2/components/amd_avalon_am29lv065d_flash -I/tools/altera/quartus5/sopc_builder/components/altera_sopc_builder -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s40 -I/tools/altera/kits/nios2/components/altera_nios2 -I/tools/altera/kits/nios2/components/altera_nios_dev_board_cyclone_2c35 -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_clock_adapter -I/tools/altera/kits/nios2/components/altera_avalon_spi -I/tools/altera/kits/nios2/components/altera_avalon_cfi_flash -I/tools/altera/kits/nios2/components/altera_avalon_dma -I/tools/altera/kits/nios2/components/altera_avalon_mailbox -I/tools/altera/quartus5/sopc_builder/components/altera_ahb_avalon_bridge -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_avalon_ahb_bridge -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_tri_state_bridge -I/tools/altera/kits/nios2/components/altera_nios_eval_board_cyclone_1c12 -I/tools/altera/kits/nios2/components/altera_avalon_lan91c111 -I/tools/altera/kits/nios2/components/altera_avalon_lcd_16207 -I/tools/altera/kits/nios2/components/altera_nios_dev_kit_stratix_edition_sram2 -I/tools/altera/kits/nios2/components/altera_avalon_cf -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_burst_adapter -I/tools/altera/kits/nios2/components/altera_nios_multiply -I/tools/altera/kits/nios2/components/altera_nios_dev_board_cyclone_1c20 -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_user_defined_interface -I/tools/altera/kits/nios2/components/altera_avalon_cy7c1380_ssram -I/tools/altera/kits/nios2/components/altera_plugs_library -I/tools/altera/kits/nios2/components/altera_avalon_cs8900 -I/tools/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s10 -I/tools/altera/kits/nios2/components/altera_avalon_jtag_uart -I/tools/altera/kits/nios2/components/altera_avalon_asmi -I/tools/altera/quartus5/sopc_builder/components/altera_avalon_onchip_memory -I/tools/altera/kits/nios2/components/altera_avalon_onchip_memory2 -I/tools/altera/kits/nios2/components/altera_avalon_timer -I/tools/altera/kits/nios2/components/altera_avalon_new_sdram_controller -I/tools/altera/kits/nios2/components/altera_nios_custom_instr_bitswap -I/tools/altera/kits/nios2/components/altera_avalon_epcs_flash_controller -I/tools/altera/kits/nios2/components/altera_avalon_performance_counter -I/tools/altera/kits/nios2/components/altera_avalon_sysid -I/tools/altera/kits/nios2/components/altera_avalon_mutex -I/tools/altera/kits/nios2/components/altera_avalon_uart -I/tools/altera/kits/nios2/components/altera_nios_custom_instruction -I/tools/altera/kits/nios2/components/altera_user_board_setup -I/tools/altera/kits/nios2/components/altera_avalon_pio /tools/altera/kits/nios2/components/altera_nios2/cpu_core_select.pl --system_name=first_nios2_system --target_module_name=cpu --system_directory=/export/home/santosh/BTP/nios_learn --sopc_directory=/tools/altera/quartus5/sopc_builder --sopc_lib_path=/export/home/santosh/BTP/nios_learn+/tools/altera/kits/nios2/components+/tools/altera/kits/megacore+/tools/altera/quartus5+/tools/altera/quartus5/sopc_builder/components --generate=1 --verbose=0 --software_only=0 --module_lib_dir=/tools/altera/kits/nios2/components/altera_nios2 --sopc_quartus_dir=/tools/altera/quartus5 --projectname=nios_learn.quartus ' Error in processing. System NOT successfully generated. Can anyone help to understand what this means I as stated b4 am a noob to this nios. So details will be greatly appreciated Thanx in advance Santosh
