14 years agoInterfacing custom module with Nios II
Hello, I have written an AES-128 Encryption module in SystemVerilog, and instead of just flashing it onto the DE2-115 board, and having it show results on LED/7-Segment's etc, I want to connect...
14 years agoI haven't never used this template but I took a quick look at it and I definitely think this is perfect for you.
Follow these steps: - replace all <slave_template> occurrences with a name you like and place the files into the \altera\<version>\ip\user_components directory - instantiate your Verilog module in slave_template.v, connecting your data i/o (namely the AES key value) to user_datain and user_dataout - add your .v files to the list in the .tcl file - the next time you open sopc builder, the new component will be available; include it in your system - rebuild all - access AES key and results with IOWR and IORD macros, as shown in .h file That's all. I hope I didn't forget anything
