instillation problems for EPCS Driver and Document
I am a relative newbie to Aletra's Nios II Ide and to Linux in general. Any ways I need to store the uClinux kernel and filesystem in EPCS flash. The tools I have am using currently are a Windows computer running Quartus II 5.1 and Nios II ide. Last week I downloaded uClinux from this forum and installed it onto the computer. Since then I have been able to run uClinux on a nios II development board using the CFI flash. The problem is the actual board I want to use uClinux on has only EPCS serial flash, which is why I was interested in using the patch from the EPCS Driver and Documentation thread.
When I try to run "patch -p0 <epcs_mtd.diff" after placing epcs_mtd.diff in C:\altera\kits\niosII5_1\bin\eclipse\plugins\com.microtronix.nios2linux.kernel_1.4.0\linux-2.6.x\drivers\mtd I get a prompted for several file names that appear to be missing. kconfig and makefile under ./mtd/maps/ and ./mtd/chips. Or atleast that is what I believe is a happening. I don't know if this is then related or not but when I do "make menuconfig" I recieve a message back "No rule to make menuconfig" Maybe I am trying to run this command in the wrong directory? I have been trying to run it out of the directory where I placed epcs_mtd.diff. Any help with my problems would be greatly appreciated. Let me know if more information is required. I believe that I am running uclinux kernel 2.6.11 but I am not positve. Thanks, John3 Replies
Unfortunately, I only support the linux toolchain build of the kernel, as Cygwin has way too many problems for me to work with. If you follow hippos buildroot guide and get the latest kernel (2.6.16.1), the EPCS driver is already included, so you don't have to patch at all. J - Altera_Forum
Where can I download the newest uClinux kernel? And how can I tell for sure which version of uClinux I have?
thanks John - Altera_Forum
Please read this thoroughly:
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) If you are using windows, you probably have 2.6.11
