20 years ago
'inittab': No such file or directory
i manage to get boa to run n serve static webpages. i want cgi, so i do according to hippo in BuildrootGuide step 14: Customize Vendor/User Settings (NEW) to select cgi generic.
when make romfs, i got this:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
chmod 620 /home/jwlam/uClinux-dist-test/romfs/dev/@[pt]ty[pqrsPQRS][0-9a-f],*
romfs-inst.sh -s /var/tmp /tmp
romfs-inst.sh /etc/inittab
cp: cannot stat `inittab&#39;: No such file or directory
make[2]: *** [romfs] Error 1
make[2]: Leaving directory `/home/jwlam/uClinux-dist-test/vendors/Altera/nios2nommu&#39;
make[1]: *** [romfs] Error 2
make[1]: Leaving directory `/home/jwlam/uClinux-dist-test/vendors&#39;
make: *** [romfs] Error 1[/b]
--- Quote End ---
bin, usr n var dir under romfs dir is empty.
pls advise. thx.
    i&#39;m still stuck... i tried using the binarytoolchain for newbie... everything went fine when making image but server display some random characters...
    hippo, pls help me with my prob in the 1st post if u c this. thx.
    --- Quote Start ---
    originally posted by tommycp@Nov 27 2006, 09:26 PM
    i aslo don&#39;t know how to make etc
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19639)
    --- quote end ---
    --- Quote End ---
    Please give your make messages.
    The uClinux-dist patches were updated to 20060803. Boa and Cgi-generic are included with default config.
    I can confitm that is working. If you guys need anymore help, I maybe able to help ?
    if are there a inittab files in the above directory?
    the command "romfs-inst.sh /etc/inittab" will copy inittab to <romfs>/etc/inittab
    So you need confirm if the file /home/jwlam/uClinux-dist-test/vendors/Altera/nios2nommu/inittab exsist.
