20 years ago'inittab': No such file or directory
i manage to get boa to run n serve static webpages. i want cgi, so i do according to hippo in BuildrootGuide step 14: Customize Vendor/User Settings (NEW) to select cgi generic. when make romfs...
19 years ago`/home/jwlam/uClinux-dist-test/vendors/Altera/nios2nommu'
if are there a inittab files in the above directory? the command "romfs-inst.sh /etc/inittab" will copy inittab to <romfs>/etc/inittab So you need confirm if the file /home/jwlam/uClinux-dist-test/vendors/Altera/nios2nommu/inittab exsist.
