21 years agoInitialization of on chip memories
Hi all,
Take a "fast" example, and add an additional on-chip memory, let's call it "common_ram". Then, from the Nios II IDE, create a helloworld project, and add a C variable definition like the following one: <div class='quotetop'>QUOTE </div> --- Quote Start --- int foobar __attribute__ ((section (".common_ram"))) = 57;[/b] --- Quote End --- Then, compile the project and debug it. the "foobar" variable has value 0 and not 57! is that related to the fact that crt0.S in altera_nios2 do not initialize the onchip memories? bye Paolo2 Replies
Paolo,
after compiling your software, a 'common_ram.hex' file is being created in your FPGA directory. You have to run SOPC builder, where you had defined the on-chip memory. Now a 'common_ram.vhd' file is present, which contains your initializing data. After compiling your FPGA in quartus, your memory will be initialized. This is the way it works with on-chip ROM. I hope this works with RAM too. Mike - Altera_Forum
Actually he need-not re-generate in SOPC Builder. The common_ram HDL file is already set to initialize using the .hex file the IDE may (or may not) produce. You should verify that such a .hex file is there, and has some bytes in it that look like initialization data. Then, re-compile in Quartus. This will initialize the on-chip RAM with the contents of the .hex file and include that with the FPGA's programming file.
