15 years agoimpossible to boot ep3c25 from epcs16 - reset_vector problem ?
I am developing my first niosII design. It works well when I use a volatile programming file (.sof) but I have issues to program the fpga with an external flash. I use : - cycloneIII ep3c25 - flash epcs16 (configuration) - ssram (nios memory) - quartus 9.1 sp2 - nios software 10.0 - windows7 x64 The hardware image seems to boot (1 led and 1 screen managed by hw are powered) but NOT the nios. When i try to run the nios manually (run as niosII hw application in eclipse) I have the following error: "Verifying 02401800 (99%) / Verify failed between address / 0x2401800 and 0x240181F / Leaving target processor paused" @02401800 is the epcs_controller base address (=reset_vector @) in the nios. I don't understand the reason of the failure. Thanks for helping ! I configure the nios in the sopc builder like that: - cypress ssram controller - epcs serial flash controller ("automatically select dedicated AS..." enabled") - cpu nios : reset_vector = epcs_flash_controller // offset 0x0 exception_vector = ssram // offset 0x20 - other modules: spi_control_port, pio, jtag, sys_clk_timer, sysid... fpga design/quartus: - flash pins are set to "use as regular IO" i use the following method to program the epcs16 :# 1) Convert SOF to Flash sof2flash --input=file.sof --output=hwimage.flash --epcs --verbose# 2) Convert ELF to Flash elf2flash --input=../testBoot.elf --output=swimage.flash --epcs --after=hwimage.flash --verbose# 3) Concatenate cp hwimage.flash hw_sw.flash cat swimage.flash >> hw_sw.flash# 4) Create HexFile nios2-elf-objcopy -I srec -O ihex hw_sw.flash hw_sw.hex Then i create a .jic file with quartus convert pgm file: - flash_loader : ep3c25 - hex_data : hw_sw.hex (I try absolute and relative addressing) I also try without concatenation : file.sof and sw.hex (relative addressing) to create the .jic file. With the same sopc file I have tested the epcs16 flash with the project template "memory test". both write and read operations work. Thanks for helping again ! SG.
