16 years agoImage compression in multiprocessor system
Hello All,
I want to design image compression using nios ii multiprocessor system.I want to design using nios II IDE. Can I get some directions or some reference code to get started?3 Replies
if you want high speed, you might consider using our JPEG-CODEC-IP, which is fast, small and reasonable priced: http://www.entner-electronics.com/tl/index.php/jpeg-codec.html Thomas - Altera_Forum
Thank you. But can I get Sorce code in c there which will be run on nios ii ide in multiprocessor configuaration.
Also I want to ask whwere I will get plenty of nios tutorials?
