20 years ago
i2c and display help
I have a Nios2 dev board (cyclone ii edition) from ALtera. I managed to load uClinux, and run it nicely. I have been able to run the LEDs and the push buttons, and ethernet.
However, I have been struggling to get I2C, SPI and 2-line char display going.
Can anyone give an insight, where I can get those IPCORE (i2c, spi) and drivers and sample app for running those things ?
I saw there is something on opencores.org, but i have no idea how to integrate them using Altrea's tools, and no way i can write drivers for them.
Perhaps this is something hippo can help.
Albert
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    where I can get those IPCORE (i2c, spi)[/b]
    --- Quote End ---
    you can download i2c from opencores. A SPI Core from Altera should be available in your SOPC Builder
    --- Quote Start ---
    drivers[/b]
    --- Quote End ---
    drivers are already in your kernel-distro. you just need to enable them when you configure your kernel
    --- Quote Start ---
    sample app for running those things ?[/b]
    --- Quote End ---
    Examples for spi and i2c are included in your microtronix-distro
    --- Quote Start ---
    I saw there is something on opencores.org, but i have no idea how to integrate them using Altrea&#39;s tools,[/b]
    --- Quote End ---
    You find some information about integration i2c in "Post your Own IP".
    Also look in the forum for more information. The "search" function helps alot
    Please also visit NiosWiki.
    --- Quote Start ---
    --- Quote Start ---
    originally posted by helmchen@Oct 23 2006, 10:15 AM
    <div class='quotetop'>quote
    --- quote end ---
    --- quote start ---
    where i can get those ipcore (i2c, spi)
    --- Quote End ---
    you can download i2c from opencores. A SPI Core from Altera should be available in your SOPC Builder[/b]
    --- Quote End ---
    I have done it, and i downloded an modified opencore i2c that can drop into sopc builder straight. Still, have no idea how to integrate it.
    --- Quote Start ---
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    [/b]
    --- Quote End ---
    I use the distro posted by hippo on nioswiki. I will find out if there is support for it.
    --- Quote Start ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18853)
    --- Quote End ---
    [/b]
    --- Quote End ---
    [/b]
    --- Quote End ---
    Thanks. I found a lot on that, and now just need to find a way to integrate it into my system.
    Anyone knows how to drive the LCD on the 2c35 nios2 dev board ?
