20 years agoi2c and display help
Hello, I have a Nios2 dev board (cyclone ii edition) from ALtera. I managed to load uClinux, and run it nicely. I have been able to run the LEDs and the push buttons, and ethernet. However...
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- where I can get those IPCORE (i2c, spi)[/b] --- Quote End --- you can download i2c from opencores. A SPI Core from Altera should be available in your SOPC Builder <div class='quotetop'>QUOTE </div> --- Quote Start --- drivers[/b] --- Quote End --- drivers are already in your kernel-distro. you just need to enable them when you configure your kernel <div class='quotetop'>QUOTE </div> --- Quote Start --- sample app for running those things ?[/b] --- Quote End --- Examples for spi and i2c are included in your microtronix-distro <div class='quotetop'>QUOTE </div> --- Quote Start --- I saw there is something on opencores.org, but i have no idea how to integrate them using Altrea's tools,[/b] --- Quote End --- You find some information about integration i2c in "Post your Own IP". Also look in the forum for more information. The "search" function helps alot Please also visit NiosWiki.
