10 years ago
I want to use own tool chain, how could i install new too chain in the DS-5?
Where is the place I can add the new tool chain from the DS-5? I wanted to use the MinGW gcc compiler. Pls help ! I am using window 7 operating system with 15.0 Soceds.
    I have the same problem, but slightly deeper:
    When trying to select toolchain (Pref/DS-5/Toolchains) on blank tab page you can see: "An error has occurred when creating this preference page".
    and textbox with caption problem occured and text inside:
    unable to create the selected preference page.
    an error occurred while automatically activating
    bundle com.arm.eclipse.build.toolchains (457).
    error log/exception stack trace:
    --- Quote Start ---
    java.lang.ClassNotFoundException: An error occurred while automatically activating bundle com.arm.eclipse.build.toolchains (457).
    at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
    at com.arm.workbench.Hook.run(Hook.java:438)
    Caused by: org.osgi.framework.BundleException: Exception in com.arm.eclipse.build.toolchains.ToolchainManagerPlugin.start() of bundle com.arm.eclipse.build.toolchains.
    at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)
    at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
    ... 171 more
    Caused by: java.lang.IllegalArgumentException: java.net.URISyntaxException: Illegal character in scheme name at index 7: initial@reference:file:../../../host_tools/mentor/gnu/arm/plugins/com.altera.ds5ae.toolchain.gcc.baremetal_16.1.0.201610250243.jar
    at com.arm.eclipse.build.toolchains.ToolchainManager.convertToURI(ToolchainManager.java:132)
    at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
    ... 178 more
    Caused by: java.net.URISyntaxException: Illegal character in scheme name at index 7: initial@reference:file:../../../host_tools/mentor/gnu/arm/plugins/com.altera.ds5ae.toolchain.gcc.baremetal_16.1.0.201610250243.jar
    at java.net.URI$Parser.fail(URI.java:2848)
    at com.arm.eclipse.build.toolchains.ToolchainManager.convertToURI(ToolchainManager.java:129)
    ... 185 more
    --- Quote End ---
    I tried to clean installation and reinstall (DS-5) only and (EDS+DS5) several times, but it doesnt help. So I failed to change TC and do build manually.
    Maybe someone have and solved the same problem ?
    PS: im using DS-5 installed with EDS 16.1.0.916 by Intel/Altera (Version: Luna SR2 (4.4.2) Build id: M20150204-1700)
    --- Quote Start ---
    --- Quote End ---
    I also had this problem when using DS-5 on Ubuntu 16.04. I had to run DS-5 as root for toolchains to work properly.
