10 years agoI want to use own tool chain, how could i install new too chain in the DS-5?
Where is the place I can add the new tool chain from the DS-5? I wanted to use the MinGW gcc compiler. Pls help ! I am using window 7 operating system with 15.0 Soceds.
9 years agoI have the same problem, but slightly deeper:
When trying to select toolchain (Pref/DS-5/Toolchains) on blank tab page you can see: "An error has occurred when creating this preference page". and textbox with caption problem occured and text inside: unable to create the selected preference page.an error occurred while automatically activating
bundle com.arm.eclipse.build.toolchains (457). error log/exception stack trace: --- Quote Start --- java.lang.ClassNotFoundException: An error occurred while automatically activating bundle com.arm.eclipse.build.toolchains (457). at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116) . . . at com.arm.workbench.Hook.run(Hook.java:438) Caused by: org.osgi.framework.BundleException: Exception in com.arm.eclipse.build.toolchains.ToolchainManagerPlugin.start() of bundle com.arm.eclipse.build.toolchains. at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792) . . . at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107) ... 171 more Caused by: java.lang.IllegalArgumentException: java.net.URISyntaxException: Illegal character in scheme name at index 7: initial@reference:file:../../../host_tools/mentor/gnu/arm/plugins/com.altera.ds5ae.toolchain.gcc.baremetal_16.1.0.201610250243.jar at com.arm.eclipse.build.toolchains.ToolchainManager.convertToURI(ToolchainManager.java:132) . . . at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764) ... 178 more Caused by: java.net.URISyntaxException: Illegal character in scheme name at index 7: initial@reference:file:../../../host_tools/mentor/gnu/arm/plugins/com.altera.ds5ae.toolchain.gcc.baremetal_16.1.0.201610250243.jar at java.net.URI$Parser.fail(URI.java:2848) . . . at com.arm.eclipse.build.toolchains.ToolchainManager.convertToURI(ToolchainManager.java:129) ... 185 more --- Quote End --- I tried to clean installation and reinstall (DS-5) only and (EDS+DS5) several times, but it doesnt help. So I failed to change TC and do build manually. Maybe someone have and solved the same problem ? PS: im using DS-5 installed with EDS 16.1.0.916 by Intel/Altera (Version: Luna SR2 (4.4.2) Build id: M20150204-1700)
