10 years agoI want to use own tool chain, how could i install new too chain in the DS-5?
Where is the place I can add the new tool chain from the DS-5? I wanted to use the MinGW gcc compiler. Pls help ! I am using window 7 operating system with 15.0 Soceds.
9 years ago --- Quote Start --- I have the same problem, but slightly deeper: ... I tried to clean installation and reinstall (DS-5) only and (EDS+DS5) several times, but it doesnt help. So I failed to change TC and do build manually. Maybe someone have and solved the same problem ? --- Quote End --- I also had this problem when using DS-5 on Ubuntu 16.04. I had to run DS-5 as root for toolchains to work properly.
