HTTP server demo not accepting connections
I've been trying the HTTP server demo, and haven't had any luck getting the demo board to accept connections from outside.
I built it according to the directions in kits/nios2/components/ecos/eCos%20for%20Nios%20II.htm, section 8, and when I ran it (using either the "hello" or "twothreads" example programs), it would successfully DHCP, obtaining the right address, servers, gateway, etc., and run the demo program. However, any connection attempt to port 80 would time out (even tried telnet). I added an FTP server, rebuilt/reinstalled, and tried to connect to port 21; nothing. Now I'm using the "ping test" ethernet test program shipped with eCos, and switched to manually configured eth0, with the same results. Here's the output from that test:nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "MasterBlaster ", device 1, instance 0
nios2-terminal: starting in terminal mode (Control-C exits)
Init: mbinit(0x00000000)
Init: cyg_net_init_devs(0x00000000)
Init device 'lan91c111_eth0'
Init: loopattach(0x00000000)
Init: ifinit(0x00000000)
Init: domaininit(0x00000000)
Init: cyg_net_add_domain(0x01061cb0)
New domain internet at 0x00000000
Init: cyg_net_add_domain(0x0106166c)
New domain route at 0x00000000
Init: call_route_init(0x00000000)
Done
Start PING test
BOOTP op: REPLY
htype: Ethernet
hlen: 6
hops: 0
xid: 0x0
secs: 0
flags: 0x0
hw_addr: 00:07:ed:0b:08:85
client IP: 10.8.1.62
my IP: 10.8.1.62
server IP: 10.4.1.2
gateway IP: 10.8.254.254
options:
subnet mask: 255.255.0.0
IP broadcast: 10.8.255.255
gateway: 10.8.254.254
Warning: Driver can't set multi-cast mode
PING server 10.4.1.2
recvfrom: Operation timed out
64 bytes from 10.4.1.2: icmp_seq=1, time=20ms
310 bytes from 10.4.1.2: icmp_seq=2, time=20ms
556 bytes from 10.4.1.2: icmp_seq=3, time=20ms
802 bytes from 10.4.1.2: icmp_seq=4, time=30ms
64 bytes from 10.4.1.2: icmp_seq=6, time=20ms
310 bytes from 10.4.1.2: icmp_seq=7, time=10ms
556 bytes from 10.4.1.2: icmp_seq=8, time=20ms
802 bytes from 10.4.1.2: icmp_seq=9, time=20ms
Route - dst: 0.0.0.0, mask: 0.0.0.0, gateway: 10.8.254.254
Sent 16 packets, received 8 OK, 0 bad
PING server 10.4.1.34
Sent 16 packets, received 0 OK, 0 bad
PASS:<Ping test OK>
EXIT:<done> Any ideas? Is there a simple socket-litener-echo test program, and if so, what is it called and what port does it listen on? And I'm still waiting for my USB Blaster rev. B (sent in the order for the "free" upgrade back in October), however, I'd like to note that I've had no problems with the MasterBlaster.15 Replies
Mike,
My guess is this is a networking configuration problem. The fact that your server is on the 10.4 subnet and the client on the 10.8 makes me suspicious. I would start with logging the packets being sent, use Ethereal or your favourite sniffer program. Hope that helps. - Altera_Forum
The eth0 settings are set in the nios2configtool, though configuring it for DHCP worked the same way.
We use the 10.x.x.x range for internal IP addresses, and the second octet is based on the department. 10.4.x.x is the IT department, 10.8.x.x is mine. All my incoming connection attempts were from 10.8.x.x addresses. I didn't know what it was asking for for "Server IP address for 'eth0'", so I put in the IP of one of our nameservers. Anyway, this morning it's decided on a new behavior. It accepts connections and replies to pings after the "recvfrom: Operation timed out", but the HTTP server doesn't return any data; it just leaves the connection open. I'm wondering if it got killed when the ping test ended... - Altera_Forum
Found another clue. It has to do with the programming procedure.
Run program_flash, then download the .sof file, then run nios2-terminal... fail. Run program_flash, press the power-on reset button, then download the .sof file before the board goes into safe mode, then run nios2-terminal... success after net threads running. - Altera_Forum
So now I can connect to the HTTP server, but my coworker can't. Strange. There is one thing I don't understand; in the Network Monitor page it's giving me:
Network Monitor Interfaces Interface Status eth0 Flags UP BROADCAST RUNNING SIMPLEX MULTICAST Address 10.8.1.62 Mask 10.8.1.62 Broadcast 10.8.255.255 lo0 Flags UP LOOPBACK RUNNING MULTICAST Address 127.0.0.1 Mask 127.0.0.1 Is the mask supposed to equal the address? Or is it a subnet mask set wrong? And what is "SIMPLEX" referring to? - Altera_Forum
Mike,
I'm afraid I'm not familiar with the Network Monitor Page. Have you thought about trying the eCos mailing lists, as this is not specific to our port. As for Simplex that means communicate in one direction at a time, as oposed to Duplex which is bi-directional simultaneously - Altera_Forum
I seem the be having the exact same issues that you're facing. Have you managed to get any further with this situation?
--Nate - Altera_Forum
I also am having the same issues. I've got a simple linxsys router (192.168.1.x) with no WAN connected. Just trying to talk to a laptop plugged in. The router's DHCP table shows the nios, but nothing works. Doing the power on reset thing doesn't work for me. I keep getting
[eth_drv_ioctl] Warning: Driver can't set multi-cast mode Any help would be appreciated. Scott - Altera_Forum
The message:
[eth_drv_ioctl] Warning: Driver can't set multi-cast mode is normal, since the LAN91C111 driver doesn't support multicast unless explicitly enabled. This shouldn't be related to the problem that you're seeing. - Altera_Forum
I've just run into what seems to be a very similar situation with a development version of the eCos kernel. After a little investigation, I found that the HTTPD stack size was too small when running DHCP (it worked using a static IP address). By default this stack is set to 2K, and it really needs to be more like 5K.
To change this in configtool, go to "Basic network framework"->"HTTP Daemon" and set "HTTPD thread stack size" to 5120. To measure stack usage, go to "eCos kernel"->"Thread-related options" and select "Measure stack usage". The stack usage information will then be available through the web server monitor pages (once you've got them working). Hope that solves your problem! - Altera_Forum
That worked!
Thanks, Scott
