21 years agoHTTP server demo not accepting connections
I've been trying the HTTP server demo, and haven't had any luck getting the demo board to accept connections from outside. I built it according to the directions in kits/nios2/component...
21 years agoThe message:
[eth_drv_ioctl] Warning: Driver can't set multi-cast mode is normal, since the LAN91C111 driver doesn't support multicast unless explicitly enabled. This shouldn't be related to the problem that you're seeing.
