9 years agoHPS GPIO's ouputs stuck in high impedence?
I have an issue regarding a custom board the GPIOs where all the HPS IO’s are set to high impedance no matter to how they are set.
I have tested the following:- GPIO system on linux enabling each of the GPIOs as an output through the controller... and writing values to them... (findings it changes to output state but the value doesn’t alter and reads back high - unchanged)
- GPIO controller address read/write (findings values don’t change)
- Pre-Linux Hardware GPIO Loaning Pins driving a value change on preloader startup to enable a LED (findings no value on GPIO changes value)
Ravi,
I am sorry you need to start with the basics... it involves creating a simple system with your cyclone v soc process (or other processor of your board) with Qsys within quartus, generate the design and create a top level design in either Verilog or VHDL hardware languages. You can then get to grips with it all. Please if you require further help follow the tutorials within this website. Although might not be available for your board you will be able to follow the process accordingly. https://rocketboards.org/ Best Regards Kyle - Altera_Forum
Hi kyle,
Thanks for your reply.I am just a starter in deo nano SOC board.My req is very simple I just wanted to access all the GPIO pins GPIO1 and GPIO0 .since I did it using the C code with HPS_LED and HPS_key I thought I just have to use the existing .SOF.But then since this did not work I generated own .SOF using system builder.But since this said no driver found I had to use qsys tool.This is where I got stuck.I just need a .sof where I can confiure the register and do the toggling and clearing.thats the requirement.so can I use the existing HPS_LED.sof and in that modify the .V file and add the .hps_0_hps_io_hps_io_gpio_inst_GPIO01 ( HPS_GPIO_1 ), // .hps_io_gpio_inst_GPIO01 will this eneble the GPIO1 and can I access the register from the linux user space.?? Need to generate .sof to create this Kindly let me know. Thanks and regards Ravi chandran - Altera_Forum
Hi Kyle,
For the exisiting .v files if I has .hps_io_....GPIO01 ==>GPIO_1 and then compile with qsys and then create .sof then I will be able to access the GPIO1 If I get an example file which has this I can add the same later I can extend this to other pins and repeat the same for GPIO0. regards Ravi - Altera_Forum
Hi Kyle,
The issue what I am facing in accessing the GPIO is more to do on the linux side.If I do an echo for 222 which is HPS led 53 then I am able to access.But the same is not possible for GPIO 29 to 34 ...this is GPIO1 or GPIO 0(1 to 8).My .SOF is fine and I am able to link to the top level. so what is the change in linux on the board needed to as to access the GPIO??..Kindly help us . regards Ravi chandran --- Quote Start --- Ravi, The Assignment editor needs to be set to Assignment Name [I/O Standard] this is a must is shouldn't be a "location" on the FPGA as there is no location it goes through into the preloader and is linked there. The Value is instead set to the Voltage level [3.3-V LVCMOS] your maybe less depending on the hps powered IO's it could be 2.5V or lower please check this. Enabled is yes too so that would be correct. Please try the linux commands from the HPS command line first (before memory mapping) to make sure that the GPIO's can be set... follow this tutorial for setting the GPIO's If there are LED's then you should be just write a active low or high signal to them from the command line.... Follow this tutorial and see if the LED's light on the gpio then you can start to progress into the memory mapping application code.. http://falsinsoft.blogspot.co.uk/2012/11/access-gpio-from-linux-user-space.html It looks like your code is correct but you need to just make sure that the GPIO is controllable from the drivers in linux the following echo commands will help you enable an GPIO output (number is significant please find out the number of the GPIO from linux and cyclone V handbook for specifying the correct GPIO) here 192 is used as this is from the GPIO controller 2 and is the 1st one your number will be different please check for your correct one. echo 192 > /sys/class/gpio/export echo "out" > /sys/class/gpio/gpio192/direction echo 1 > /sys/class/gpio/gpio192/value echo 0 > /sys/class/gpio/gpio192/value The first echo line enables the gpio.... if you get problems here the gpio is already attached to a linux driver and will need removing (look into removing a driver) The second enables that channel to become an output as all gpio's are either in or output the default is always input so this enables you send the gpio as high or low...etc The next 2 lines will write a high or low value to that gpio you should see the light move on and off if it is correctly enabled. Best of luck Kyle Without finding problems you never learn. --- Quote End --- - Altera_Forum
Hi Ravi,
It seems you have setup the GPIO's correctly in the .SOF file and are able to access them through linux, so if the GPIO 29 to 34 are linked correctly (or not connected to any HPS controller i.e. SPI, UART etc) and you have doubled checked this. Then your right to assume its a Linux resolution. What I suggest is you perform the following sequence within linux to correctly make sure no other drivers are linked to the device. To see how the GPIO's are setup for the working pins and also duplicate this driver for the non-working pins. These are the steps: cat /sys/kernel/debug/gpio The above command in Linux performs a category display of the kernel gpio pins... if you have any drivers linked to the gpio numbers it will say here. So from this information you need to see if any drivers are linked to the working pins? (e.g. GPIO 222 / HPS_LED 53) - If they are you will need to duplicate this driver by binding it to the correct driver. You can do this in Linux or via the Linux Device Tree for a custom built development it suggest just copy the other GPIOs to to a driver and they are linked. Alternatively if this suggest no drivers are connected to the pins and they are all GPIO output enabled then you need to see if the non-working ones are binded to a driver such as "led-gpio" or alternate drivers dependable on your system configuration. If they are this means they are uncontrollable from this point as they are attached direct to a specific driver and need to be un-binded first. (This can be again done in the linux device tree look at where the GPIO's are set up remove and create a new device tree). Or an alternate method would be just to unbind it from Linux itself using the following command syntax below: echo "leds-gpio" > /sys/bus/platform/drivers/leds-gpio/unbind Please note where it says leds-gpio for both the echo and driver you need to alter for exactly the same driver that is linked to you system you should then be able to read and write to these GPIO's.. Does this makes sense? Best of Luck Kyle - Altera_Forum
Hi kyle,
yes this path really make sense.Now to answer your points I have following observations 1.when I do cat /sys/kernel/debug/gpio I see the following things GPIOs 171-197, /soc/gpio@ff70a000: GPIOs 198-226, /soc/gpio@ff709000: gpio-199 (sysfs ) out hi gpio-222 (sysfs ) out hi GPIOs 227-255, /soc/gpio@ff708000: when I configure for pin 222 ->HPS_53 and 199->GPIO30 following is oberserved GPIOs 198-226, /soc/gpio@ff709000: gpio-199 (sysfs ) out hi gpio-222 (sysfs ) out hi The gpio-222 is linked to HPS_53 and I am able to control through the linux command. value says "hi" here for both but gpio-199 is not seen glowing. 2. while I tried executing your command for unbind echo "leds-gpio" > /sys/bus/platform/drivers/leds-gpio/unbind following error observed:-sh: echo: write error: No such device Any pointers to get over these errors and accessing the pins??? Thanks Ravi - Altera_Forum
Hi ravi,
It seems that there isn't anything bound from your debug list.... only the gpio's are set to the 3 controllers of the GPIO core which is as expected. So from the GPIO point of view... GPIOs 227 to 255 would be linked to GPIOs 0 to 28 GPIOs 198 to 226 would be linked to GPIOs 29 to 57 GPIOs 171 to 197 would be linked to GPIOs 58 to 66 so GPIO 226 = GPIO 57 ---> from your design pin so GPIO 222 = GPIO 53 ---> from your design pin so GPIO 199 = GPIO 30 ---> from your design pin (I think this is not the correct GPIO number from what you have said) So this is the mix up.... your not connected to the correctly controller GPIO number.... So if from your design pin when you want GPIO 0 you need GPIO 227 to be exported... Hope this helps you Many Thanks Kyle - Altera_Forum
Hi kyle ,
even if I export 227 the pin is not glowing this is more to do with unbinding from linux as suggested by you last time while I tried executing your command for unbind echo "leds-gpio" > /sys/bus/platform/drivers/leds-gpio/unbind following error observed:-sh: echo: write error: No such device Any pointers to get over these errors and accessing the pins??? Let me know how I can make the pins unbind....then all the pins shall be accessed. regards Ravi chandran - Altera_Forum
Hi kyle ,
with respect to GPIO 0 also this is what is seen when I do cat /sys/kernel/debug/gpio GPIOs 171-197, /soc/gpio@ff70a000: GPIOs 198-226, /soc/gpio@ff709000: GPIOs 227-255, /soc/gpio@ff708000: gpio-227 (sysfs ) out hi gpio-228 (sysfs ) out lo but 227 and 228 which corresponds to GPIO 0[0] and GPIO_0[1] does not glow....Linux is binding I think ..if I do unbind echo "leds-gpio" > /sys/bus/platform/drivers/leds-gpio/unbind -sh: echo: write error: No such device so I need to get over this problem so as to access GPIO's..what is the way to do this??..any idea. regards Ravi - Altera_Forum
Hi ravi,
They are not bound in your case.. there is nothing obvious on your debug list... except the controllers and this is normal. As your device tree would have something like this included to attach the GPIOs to the memory locations: hps_0_gpio0: gpio@0xff708000 { compatible = "snps,dw-gpio-14.0", "snps,dw-gpio"; reg = < 0xFF708000 0x00001000 >; interrupt-parent = < &hps_0_arm_gic_0 >; interrupts = < 0 164 4 >; clocks = < &l4_mp_clk >; # gpio-cells = < 2 >; gpio-controller; }; //end gpio@0xff708000 (hps_0_gpio0) hps_0_gpio1: gpio@0xff709000 { compatible = "snps,dw-gpio-14.0", "snps,dw-gpio"; reg = < 0xFF709000 0x00001000 >; interrupt-parent = < &hps_0_arm_gic_0 >; interrupts = < 0 165 4 >; clocks = < &l4_mp_clk >; # gpio-cells = < 2 >; gpio-controller; }; //end gpio@0xff709000 (hps_0_gpio1) hps_0_gpio2: gpio@0xff70a000 { compatible = "snps,dw-gpio-14.0", "snps,dw-gpio"; reg = < 0xFF70A000 0x00001000 >; interrupt-parent = < &hps_0_arm_gic_0 >; interrupts = < 0 166 4 >; clocks = < &l4_mp_clk >; # gpio-cells = < 2 >; gpio-controller; }; //end gpio@0xff70a000 (hps_0_gpio2) Have you tried other GPIO's? Perhaps its your circuit or you have included a device on your GPIO's such as a peripheral (UART, SPI or CAN controller) to these pins in Quartus Qys design and is not configurable. Or you have forgotten to add it again in the pin assignments like you did originally with the first GPIO's this could be your issue. regards Kyle
