9 years agoHPS GPIO's ouputs stuck in high impedence?
I have an issue regarding a custom board the GPIOs where all the HPS IO’s are set to high impedance no matter to how they are set. I have tested the following: GPIO system on linux enablin...
9 years agoHi Kyle,
For the exisiting .v files if I has .hps_io_....GPIO01 ==>GPIO_1 and then compile with qsys and then create .sof then I will be able to access the GPIO1 If I get an example file which has this I can add the same later I can extend this to other pins and repeat the same for GPIO0. regards Ravi
