9 years agoHPS GPIO's ouputs stuck in high impedence?
I have an issue regarding a custom board the GPIOs where all the HPS IO’s are set to high impedance no matter to how they are set. I have tested the following: GPIO system on linux enablin...
9 years agoHi kyle ,
even if I export 227 the pin is not glowing this is more to do with unbinding from linux as suggested by you last time while I tried executing your command for unbind echo "leds-gpio" > /sys/bus/platform/drivers/leds-gpio/unbind following error observed:-sh: echo: write error: No such device Any pointers to get over these errors and accessing the pins??? Let me know how I can make the pins unbind....then all the pins shall be accessed. regards Ravi chandran
