21 years agoHow to use ecos on niosii
I am a fresher about ecos .Now after I've installed ecos and niosii1.01 ,I used ecos ,but found some errors which listed below:
1. make[1]: *** [/cygdrive/c/DOCUME~1/Administrator/MYDOCU~1/ecos- work/ai_install/include/cyg/hal/system.h] Error 127 2.make[1]: Leaving directory `/cygdrive/c/DOCUME~1/Administrator/MYDOCU~1/ecos-work/ai_build/hal/nios2/arch/v2_0' make: *** [build] Error 2 what about it and how can I resolution it ? thanks in advance.1 Reply
Your problem description is lacking a little context (what did you do to cause the problem?) , I would recommend that you follow the instructions which can be found in the file altera\kits\nios2\components\ecos\eCos for Nios II.htm. To build the simple examples. There is also a separate forum devoted to eCos where these questions should be posted.
