21 years agoHow to use ecos on niosii
I am a fresher about ecos .Now after I've installed ecos and niosii1.01 ,I used ecos ,but found some errors which listed below: 1. make[1]: *** [/cygdrive/c/DOCUME~1/Administrator/MYDOCU...
21 years agoYour problem description is lacking a little context (what did you do to cause the problem?) , I would recommend that you follow the instructions which can be found in the file altera\kits\nios2\components\ecos\eCos for Nios II.htm. To build the simple examples. There is also a separate forum devoted to eCos where these questions should be posted.
