15 years agoHow to update .mif data from on chip ram????
Hi, I have create avalon-MM slavo part for my 1 port RAM and I use .mif file as my memory file for my 1 port RAM. When I run in Nios2 IDE software, I can read all the .mif data successfully. ...
15 years agoAnd do not forget to re-run the assembler after that.
Basically: 1. change .mif file(s) 2. select Update Memory Initialization File in Quartus processing menu 3. run the assembly step
