20 years agoHow to run uClinux on UP3 board?
I select the Microtronix Cyclone board for option of "Platform",and build the Kernel project successfully.
On the next step of "building filesystem", as I select my ptf file,IDE show the warning: available memory space 0 k .(Flash on UP3 is 1M*16bit ) and IDE refuse to upload romfs.bin file. Does anyone succeed to run UClinux on UP3? What can I do for the problem?5 Replies
Hi yks2003,
> Does anyone succeed to run UClinux on UP3? Shoot Justin a PM ... he already blazed this trail with both u-boot and uClinux ... and he was successful. Justin (LiangYi): http://www.niosforum.com/forum/index.php?showuser=1359 (http://www.niosforum.com/forum/index.php?showuser=1359) Regards, --Scott - Altera_Forum
--- Quote Start --- originally posted by yks2003@Nov 4 2005, 08:15 AM i select the microtronix cyclone board for option of "platform",and build the kernel project successfully.on the next step of "building filesystem", as i select my ptf file,ide show the warning: available memory space 0 k .(flash on up3 is 1m*16bit ) and ide refuse to upload romfs.bin file.
does anyone succeed to run uclinux on up3?
what can i do for the problem?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10789)
--- quote end ---
--- Quote End --- smcnutt, thanks for your reply!
--- Quote Start --- originally posted by smcnutt@Nov 4 2005, 09:33 AM hi yks2003,> does anyone succeed to run uclinux on up3?
shoot justin a pm ... he already blazed this trail with both u-boot and uclinux ... and
he was successful.
justin (liangyi): http://www.niosforum.com/forum/index.php?showuser=1359 (http://www.niosforum.com/forum/index.php?showuser=1359)
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10792)
--- quote end ---
--- Quote End --- I cannot find the web.why? "The requested URL was not found on this server."
Hi phill,
> I cannot find the web.why? It's a link from the old forum app -- try the following, it should be helpful: http://forum.niosforum.com/forum/index.php...opic=2501&st=0# (http://forum.niosforum.com/forum/index.php?showtopic=2501&st=0#) Regards, --Scott - Altera_Forum
The UP3 has very small sram , 1MB, and it is almost impossible for nios2 uClinux.
You should get a dev board with 8M+ sdram to run uClinux. You can play only HAL on UP3.
