20 years agoHow to run uClinux on UP3 board?
I select the Microtronix Cyclone board for option of "Platform",and build the Kernel project successfully. On the next step of "building filesystem", as I select my ptf file,IDE show the warning...
20 years agoThe UP3 has very small sram , 1MB, and it is almost impossible for nios2 uClinux.
You should get a dev board with 8M+ sdram to run uClinux. You can play only HAL on UP3.
