20 years agoHow to port apps to uClinux
This is about how to port applications to uCLinux on nios2. I will take mtools-3.9.10 as an example.
If you are a newbie, read the FAQ on www.ucdot.org. There is no MMU, so no virtual memory, no fork, and stack size is fixed. The exec format is not ELF, but binary flat format, FLT. Some apps will run, some will not run. (marc) Some will run with small data, but fail with large data. First, read the INSTALL. If it need "./configure", run it. A Makefile will be generated. You will have to modify the Makefile or Rules.mak. To fixup the cc and libs flags. Remove unused items, or that is for PC host. Then, "make" "make install" The binary and links will be install to $(ROOTS)/usr/local/bin. Note, the stack size is specified as "-s 16000" to elf2flt in the ldflags, for about 16KiBytes here. You can change it to other value with decimal. Hex is not allowed with it. copy the mtools.conf to $(ROOTFS)/etc, and set C: for /dev/hda1. I try out the binary.# modprobe vfat# mkdir /mnt/v1# PATH=$PATH:/usr/local/bin# fdisk /dev/hda# mformat -t 124 -h 255 -n 63 C: Ohhh.., it failed with "Allocation of length 8228864 from process 27 failed". Rebuild the kernel with [*] Allow allocating large blocks (> 1MB) of memory and try again with,# mformat -t 2000 -h 16 -n 63 c:# mount -t vfat /dev/hda1 /mnt/v1 HaHa!! It works. Just the (head * sector) can not be too large, (255 * 63) will fail. The patch to the Makefile for mtools,--- Makefile 2006/01/06 06:17:29 1.1
+++ Makefile 2006/01/06 06:38:58
@@ -6,10 +6,14 @@
# a lock method... either -DLOCKF, -DFLOCK, or -DFCNTL and put that
# string in the CFLAGS line below.
+UCLIBC_PLUGIN = /usr/local/src/nios2/build/uClibc_dev
+KERNEL_BUILD_DIRECTORY = /usr/local/src/nios2/linux-2.6.x
+ROOTFS = /usr/local/nios2-elf/src/nios2/build/rootfs
# User specified flags
-USERCFLAGS =
-USERLDFLAGS =
-USERLDLIBS =
+USERCFLAGS = -nostdinc -I$(UCLIBC_PLUGIN)/include -I$(KERNEL_BUILD_DIRECTORY)/include -funsigned-char -iwithprefix include -Dfork=vfork -D__uClinux__
+USERLDFLAGS = -nostdlib -Wl,-elf2flt="-s 16000" -Wl,-v -Wl,-d -L$(UCLIBC_PLUGIN)/lib $(UCLIBC_PLUGIN)/lib/crt0.o
+USERLDLIBS = -lc -lm -lgcc
MAKEINFO = makeinfo
TEXI2DVI = texi2dvi
@@ -26,23 +30,23 @@
srcdir=.
-prefix = /usr/local
+prefix = $(ROOTFS)/usr/local
exec_prefix = ${prefix}
bindir = ${exec_prefix}/bin
infodir = ${prefix}/info
mandir = ${prefix}/man
sysconfdir = ${prefix}/etc
-CC = gcc
+CC = nios2-elf-gcc
CXX = @CXX@
MYCFLAGS = -g -O2 -Wall
MYCXXFLAGS = @CXXFLAGS@
CPPFLAGS =
HOST_ID = -DCPU_i686 -DVENDOR_pc -DOS_linux_gnu
-DEFS = -DHAVE_CONFIG_H -DSYSCONFDIR=\"$(sysconfdir)\" $(HOST_ID)
+DEFS = -DHAVE_CONFIG_H -DSYSCONFDIR=\"$(sysconfdir)\"
LDFLAGS =
-LIBS = -lbsd -lnsl
+LIBS =
SHLIB =
MACHDEPLIBS =
LN_S = ln -s
@@ -122,10 +126,10 @@
mlabel mmd mmount mmove mpartition mrd mren mtype mtoolstest mshowfat
mbadblocks mzip
-X_CFLAGS = -I/usr/X11R6/include
-X_LIBS = -L/usr/X11R6/lib
+X_CFLAGS =
+X_LIBS =
X_EXTRA_LIBS =
-X_PRE_LIBS = -lSM -lICE
+X_PRE_LIBS =
CFLAGS = $(CPPFLAGS) $(DEFS) $(MYCFLAGS) -fno-strict-aliasing -I. -I. $(USERCFLAGS)
CXXFLAGS = $(CPPFLAGS) $(DEFS) $(MYCXXFLAGS) -I. -I. $(USERCFLAGS)
LINK = $(CC) $(LDFLAGS) $(USERLDFLAGS)
@@ -133,7 +137,7 @@
X_LDFLAGS = $(X_EXTRA_LIBS) $(X_LIBS) $(X_PRE_LIBS) -lXau -lX11 $(LIBS)
X_CCFLAGS = $(X_CFLAGS) $(CFLAGS)
-all: mtools $(LINKS) mkmanifest floppyd floppyd_installtest
+all: mtools $(LINKS)
%.o: %.c
$(CC) $(CFLAGS) -c $<
@@ -217,8 +221,7 @@
uninstall-info:
cd $(infodir) && rm -f mtools.info*
-install: $(bindir)/mtools $(bindir)/floppyd $(bindir)/floppyd_installtest install-man install-links
- $(bindir)/mkmanifest install-scripts install-info
+install: $(bindir)/mtools install-links
uninstall: uninstall-bin uninstall-man uninstall-links
uninstall-scripts6 Replies
It's very good.Thank you, hippo!!!
Can you tell me what cross compiler you used? Is microtronix Nios II Cross Development Kit ? Alex - Altera_Forum
I built the tools on Linux, as you knew.
I didn't try it on Widnows, but the patch can be easily adapted. I am not sure if sym-link works on cygwin? Maybe some one can try out. One minor issue in my first post, the crt1.o is for the lastest uClbc snapshot. It should be spelled as crt0.o for your case. If you follow marc's site to build toolschain, it is even more simple to do the job. The nios2-elf-gcc should be spelled as nios2-linux-uClibc-gcc. And -nostdinc incdirs and -nostdlib crt0.o libs libdirs can be omited, because they are compiled into uClibc default. - Altera_Forum
thanks hippo.
I want to porting ucd-snmp4.1.2 to nios2 uclinux. so I must select a cross compiler. I wish Marc's toolschain can be used. - Altera_Forum
You migh check the net-snmp, (former ucd-snmp), port in buildroot's apps.
Or in uClinux-dist's user. But they are more complicated. For ucd-snmp4.1.2, ./configure and fix up the generated makefiles and config.h. - Altera_Forum
alex824:
Alternatively, you can use marc's toolchain binaries to build net-snmp from its main source. I was able to do that successfully with some help from hippo. See http://forum.niosforum.com/forum/index.php?showtopic=3186 (http://forum.niosforum.com/forum/index.php?showtopic=3186). - Altera_Forum
TO_BE_DONE
