20 years agoHow to port apps to uClinux
This is about how to port applications to uCLinux on nios2. I will take mtools-3.9.10 as an example. If you are a newbie, read the FAQ on www.ucdot.org. There is no MMU, so no virtual memory, no...
20 years agoalex824:
Alternatively, you can use marc's toolchain binaries to build net-snmp from its main source. I was able to do that successfully with some help from hippo. See http://forum.niosforum.com/forum/index.php?showtopic=3186 (http://forum.niosforum.com/forum/index.php?showtopic=3186).
