20 years agohow to modify the ethernet driver
dear all,
I do according to hippo, now i can run uclinux on my custom board ,because my board is not the altera board ,so i should modify the lan91c111 driver ,could you give me how to modify the ethernet driver? best regards3 Replies
--- Quote Start --- originally posted by nwpu_zhf2004@Jul 2 2006, 11:04 PM dear all,i do according to hippo, now i can run uclinux on my custom board ,because my board is not the altera board ,so i should modify the lan91c111 driver ,could you give me how to modify the ethernet driver?
best regards
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16609)
--- quote end ---
--- Quote End --- If you follow altera dev board to design your scm91111, it should run without modification. check include/nios2_system.h does the uclinux detect smc91111 during bootup?
I have ever run a web server on my costum board(LAN91C111 is work in 16 bit with nios2,this is not same altera dev board)with uCOS2.I think the hardware of 91c111 is good.
Now I compile the 91c111 driver into the uClinux,but the 91c111 does not run because the led of the J45 is not light. Should I modfide the 91c111 driver? - Altera_Forum
--- Quote Start --- originally posted by nwpu_zhf2004@Jul 3 2006, 12:48 PM i have ever run a web server on my costum board(lan91c111 is work in 16 bit with nios2,this is not same altera dev board)with ucos2.i think the hardware of 91c111 is good.now i compile the 91c111 driver into the uclinux,but the 91c111 does not run because the led of the j45 is not light.
should i modfide the 91c111 driver?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16619)
--- quote end ---
--- Quote End --- in drivers/net/smc91111.c try define CONFIG_SMC16BITONLY
