20 years agohow to modify the ethernet driver
dear all, I do according to hippo, now i can run uclinux on my custom board ,because my board is not the altera board ,so i should modify the lan91c111 driver ,could you give me how to mod...
20 years agoI have ever run a web server on my costum board(LAN91C111 is work in 16 bit with nios2,this is not same altera dev board)with uCOS2.I think the hardware of 91c111 is good.
Now I compile the 91c111 driver into the uClinux,but the 91c111 does not run because the led of the J45 is not light. Should I modfide the 91c111 driver?
